1982 318 4-barrell intake and carb.needed
Old May 6, 2006 | 03:03 AM
jim747's Avatar
jim747
Default 1982 318 4-barrell intake and carb.needed
My son wants a 4-barrell intake and carb. for 82 dodge truck 318 that he got from his grandmother.THANKS
Old May 8, 2006 | 04:57 AM
joschmo86's Avatar
joschmo86
Default RE: 1982 318 4-barrell intake and carb.needed
summitracing.com or jegs.com have decent prices. good luck
Old May 8, 2006 | 07:42 AM
horatio102's Avatar
horatio102
Stock 360 4-bbl intake manifold works just about as well as the Edelbrock Performer series, and it's inexpensive if you can find one local. Get a 600cfm carb, I'd recommend a Holley or OEM Rochester.
Old May 8, 2006 | 02:19 PM
DodgeRam318_4bbl's Avatar
DodgeRam318_4bbl
I'd prefer the Edelbrock over the stock one since the Edelbrock one weighs less than half of the weight of the stock one.
Old May 8, 2006 | 03:35 PM
horatio102's Avatar
horatio102
That's your preference. The fact is that performance wise there's very little gain compared to a stock one, except for the weight. The price, on the other hand, is quite different. Swap meet or junkyard iron manifolds can be had for really cheap, whereas an aluminum manifold will cost a lot more. Brand new they're what, $200 something. With that kind of price savings you can pick up a good set of plug wires, plugs, cap/rotor, coil, and probably the orange ECM as well.
Old May 14, 2006 | 04:12 PM
powerram1985's Avatar
powerram1985
ORIGINAL: horatio102
very good point. i went with the 600 cfm holley on a edelbrock performer intake. it looks great. but the old iron would be far more cost effective. also if you get the edelbrock intake it sets higher than the stockers and needs a different throttle cable bracket.
Old May 31, 2006 | 02:08 PM
DodgeRam318_4bbl
Good points on the manifold, guys. As for the carb, don't get anything bigger than a 650 c.f.m. Anything bigger will pump too much into the engine.
