Ram B250 Odometer problem
Old May 14, 2006 | 08:26 PM
Jac's Avatar
Jac
Default Ram B250 Odometer problem
Hello,
Since a few weeks I own a 1993 Dodge Ram B250 Conversion Van.
Only with a not working Odometer.
So I have taken the meters out and found out that the little motor at the back of the Speedometer was missing.
Probably taken out by the former owner with the idea that it causes the problem of the Odometer.
Bought a used meter cluster and replaced the little motor and also the print board to which it is connected.
But apparently this was not the reason that the Odometer don’t work. Means, he still don’t work.
Conclusion, it is probably caused by something else, wiring, sensors, or ???
Is there someone who have any suggestion and/or ideas of things to check, or what probably causes this problem?
Greetings,
Jac.
Old May 22, 2006 | 09:08 PM
DodgeRam318_4bbl's Avatar
DodgeRam318_4bbl
Default RE: Ram B250 Odometer problem
Check the speed sending unit at the back of the transmission.
