A few 1985 350 questions.
Old Oct 19, 2006 | 05:30 PM
jhouk2000's Avatar
jhouk2000
Default A few 1985 350 questions.
I recently bought this truck out of a feild. The previous owner didn't know a lot about it.
I was wondering how I could find out the engine size. (castings on the block?)
Also I would like to know the rear end ratio but I don't know where to look.
It has a lot of power and gets about 4 mpg so I assume its a 360 with a 4:10 but I would like to know for sure.
Another thing is it barely holds oil preasure, not like my other '85 which always holds good preasure. I am still using the stock psi gauge and I don't think it accurate, can I put a mechanical gauge on it?
Sorry for the long post. I would just like to get this truck going.
Old Oct 19, 2006 | 10:28 PM
horatio102's Avatar
horatio102
Default RE: A few 1985 350 questions.
You could decode the VIN to figure out what engine it came with, but that doesn't always tell you what's in it. If it's a small block then the distributor will be between the firewall and carb, and on the driver's side towards the back just under the head there should be a casting that shows displacement. If the distributor is up front, then it's a big block probably swapped in.
I get 9-11mpg in my 86 lifted 4x4 with the 360 and 4.10s, so there's something wrong if you're only getting 4.
As for ring and pinion ratio, there should be a tag bolted to the diff cover. If not, then you'll have to mark the driveshaft and jack the rear end up and count revolutions - driveshaft/tire.
Old Oct 26, 2006 | 04:25 PM
dodgedakotacrazy's Avatar
dodgedakotacrazy
if you scrape off just under the drivers side head on the front on the block its stamped there if small block on a bigblock its on the left side by the dist. on a little 1 or 2 X 1 or 2" square pad that has the displacement...also on the Drivers? if not drivers passenger side its casted on the side of the block...also the title says 350 question i'm guessing thats a typo?? i'll get pics of the locations if needed
Old Oct 31, 2006 | 11:48 AM
jhouk2000's Avatar
jhouk2000
Thanks for the help guys. I am gonna check it out this afternoon if the rain holds off.
I ment 350 as the size of the truck, not the engine.
Old Oct 31, 2006 | 04:20 PM
dodgedakotacrazy
oh sorry.....
