Body lift help: Broken bolt!!!
Today, i started to put a body lift on my 1991 dodge d250, and the front passengers side of the cab body mount bolt snapped flush off with the cab. Has anybody had this problem, and what is the easiest way to get the bolt out?
I have always had good luck with an "easy out". You can find them in most auto stores. Drill a hole in the bolt and hammer while turning the easy out in the hole you drilled. Of course, make sure to spray the heck out of the bolt with WD or somthing first, as you can break the tool in the process, and potentially complicate the job!
