1984 ram 250 loosing power
Old Jan 6, 2007 | 02:34 PM
tc's Avatar
tc
Default 1984 ram 250 loosing power
I've got a 1984 ram 250 and it seems to be loosing power. I Replaced the Battery and the alt but I am still loosing power ( Lights dim and no blinkers, no radio). I was thinking it might be the voltage regulator. I had a 1987 that did the same thing but I cant rember if it was the voltage regulator that I ended up changing as well as the battery and the alt? Any Ideas
Old Jan 8, 2007 | 03:58 AM
topsites's Avatar
topsites
Default RE: 1984 ram 250 loosing power
Have you cleaned your battery's terminals and posts with a wire brush cleaner?
They sell ones just for that at the store, like $2-$3 or so.
Make sure they're really nice and clean
Old Jan 14, 2007 | 06:35 AM
Chump's Avatar
Chump
Replace the voltage regulator and make sure your drive belt is tensioned correctly.
Old Mar 30, 2013 | 01:53 PM
deadline69's Avatar
deadline69
I have a 1984 w 150 318. I replaced the voltage regulator and the truck was charging at about 16 v and ran like a raped ape. Then about ten min later it started having really bad speratic idles. And died on me and wont start up to save my life . Before I replaced the regulator the same thing was happening. Should I change the single pick-up or just the regulator to see if that is the real problem and why would the voltage regulator allow the 318 to idle smooth. ?????
Old Mar 30, 2013 | 01:54 PM
deadline69's Avatar
deadline69
Also I have the problem if it is idling some what good when I turn the headlights on it goes crazy and dies out.
