electrical problem??
Old Jan 8, 2007 | 03:07 AM
irwilly's Avatar
irwilly
Default electrical problem??
I have a 94 dakota with tilt wheel. Sometimes the blower motor, electric windows will stop working while driving. I tilt the wheel up and down hard, then things work again. Also the airbag lamp goes on when the blower motor and windows will not work, but goes out when the when is tilted up and down. Any idea's???? Where can I get a wiring diagram for these circuits??
Thanks, Bill
Old Jan 9, 2007 | 08:57 PM
kurts2's Avatar
kurts2
Default RE: electrical problem??
The first thing that pops into my head, is your ignition switch. If the yellow wire from the switchis loose, or the switch is going bad, the accessories can go off line (it's like turning the key off). The reason the truck still runs, is that's a diffrent circuit. Next time, try to jiggle the key a bit or just bang on the switch
Old Jan 14, 2007 | 06:24 AM
Chump's Avatar
Chump
The blower and windows get there power from the ignition switch thru the fuse block. sounds like your switch or it's wiring connector is bad
