need d-100 318 to 360 help
Old Jan 30, 2007 | 02:04 AM
Jeffmarble's Avatar
Jeffmarble
Default need d-100 318 to 360 help
i have a ready to go 360 and tf 727 ready to drop in a 73 d-100 my concern is one the flex plate i got when i got the motor its small almost like a cross i believe for internally balanced motors but from what i understand the 360 is external.
the motor is from a b-300 van from 79 origanally i dont know if the oil pan will work either has well has motor mounts
i dont have any for the 360 just my 318 also should i keep my thermoquad? i dont know its current cfm i have a edelbrock but its only 600cfm the motor is almost stock it has headers bolted on trw pistons stock comp port matched and polished also the intake is a edelbrock victor and a hd rv cam from comp cams
my old motor is a 318 from 79 and has a tf 904 the new one is a 79 360 with a tf727 from a b300 van plzzz help
Old Jan 31, 2007 | 04:17 AM
horatio102's Avatar
horatio102
Default RE: need d-100 318 to 360 help
1) Get a new torque converter/flex plate, and get quality. The 360 doesn't use the same as the 318, but you can get a weight kit to weld on, but imho it's better off doing it right.
2) Oil pan probably won't work. My buddy has a 73 w100 that he put a 318 out of a 78 van. Oh, yours is 2wd, it might be fine.
3) Carb - thermoquads are good, you could go either way though, the 600 cfm Eddy would be fine as well. Stock/mild 360s only need about 570-600 cfm anyway.
Old Feb 1, 2007 | 04:23 AM
Jeffmarble's Avatar
Jeffmarble
the guy rebuilding my trans told me my current flexplate will be fine if i get a externally balanced torque converter does that sound right?
and will the trans drop inwithout drive shaft mods going 904 to 727?
also while its out anything else i may has well do im converting my stock points to elec also getting advance springs and the summit cap/rotor wires kit got the ngk r's headers and 2.5 inch mufflers anything i may be missing to get this thing running good?
Old Feb 1, 2007 | 02:46 PM
horatio102's Avatar
horatio102
The driveshaft I'm not sure about, you'll have to measure the length of both trannies and check to get the correct U-joint, since you may need to get one that adapts between different sizes.
Are you getting the Mopar Orange ECM and distributor kit? If not, get the Orance ECM and get a good coil. Also, get a 14x3 or 4" K&N open filter. I noticed a HUGE improvement when I switched from stock filter to a larger open element. The stock one was choking my engine.
Old Feb 2, 2007 | 04:40 AM
Jeffmarble's Avatar
Jeffmarble
also do you know if i needed a differant motor mount or bracket i read somewhere i may need a differant one for the left side i believe im not sure.
i already got a 14 inch edelbrock with there paper element it made a dif on the 318 so hopefully i get this thing to be a good runner i really hope i can start chirpin tires. i dont got the mopar orange i have another performance one dont remeber the type got the accel coil. any how if i dont get a reply back ill post some pictures of my finished product ive dropped enough money in it to show it off lol
after this though next is that rear end a open dif is kinda annoying
