hot starter
Old Mar 11, 2007 | 03:58 AM
D150project's Avatar
D150project
Default hot starter
is my starter getting too much heat from my hedders?
Old Mar 11, 2007 | 07:16 PM
dtherren's Avatar
dtherren
Default RE: hot starter
More than likely if it keeps going bad. They make heat deflectors.
Old Mar 16, 2007 | 05:59 PM
440ram's Avatar
440ram
my starteer went bad. couple of things you can do, first its more expensive put look into having the headers ceramic coated this will reduce headers surface temp by almost 300 degrees and or buy starter heat sheild from jegs and cut it to fit you starter and slip it over
Old Mar 18, 2007 | 06:58 PM
moparmudder's Avatar
moparmudder
look in jegs or summit or any performance catalog maybe even at ur local auto store they have header whraps that keep the heat in the pipes where they belong im sure this will help u greatly
