2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
recommendation for trunck ground location?
Old Dec 24, 2007 | 11:05 PM
mpdej8's Avatar
mpdej8
Default recommendation for trunck ground location?
Does anyone have a good recommendation as to where I should attach my amplifier ground wire in the trunk? Or should I just drill a hole anywhere on the metal and attach it?
Thanks.
Old Dec 25, 2007 | 03:44 AM
futil's Avatar
futil
Default RE: recommendation for trunck ground location?
The rear seat bolt is agood amp ground.. I have my amp hooked upat that location..
It should be a more solid ground location than a drilled hole since you can apply more torque to it and not have to worry about stripping it. Since you can make it tighter, there should be less chance of it vibrating lose.
