2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Replacing fog light bulbs
Old Jan 20, 2008 | 01:55 PM
fenderman's Avatar
fenderman
Default Replacing fog light bulbs
Hey, anyone replace their fog bulbs yet? My driver sider blew, but it seems like I need to remove the plastic fender molding to get to the bulb. Anyone do it? Which screws did you remove?
Old Jan 22, 2008 | 09:34 AM
Silkk19's Avatar
Silkk19
Default RE: Replacing fog light bulbs
I removed two screws on the fascia that sits right in front of the wheel. You may have to turn the wheel to get to it. Once you unscrew the two screws you have to pull back to fascia a bit so you can get your hand in there. It will seem a little awkward because you have to pull the fascia out of the wheel well, if that makes sense. Than about a foot in is the bulb connection where all you do is turn and disconnect the cable and install the new bulb. Hope that helps. Let me know if you got it to work.
Old Jan 27, 2008 | 03:24 PM
fenderman's Avatar
fenderman
ORIGINAL: Silkk19
Hey, Just had time to change the bulb. I misunderstood your post and first removed the 2 clips on the bottom. Then I realized that you meant the 2 hex screws on the side. Since I had the bottom clips off i was able to remove the bottom hex screw and pull out the fascia to change the bulb, but it would be much easier if i did it your way. Major pain either way. Thanks
