2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
MyGIG Hard Drive Info
Old Mar 29, 2008 | 06:10 PM
jspies's Avatar
jspies
Default MyGIG Hard Drive Info
I don't know if anybody is interested, but I pulled the HD out of the MyGIG, connected it to a laptop and booted with Knoppix Linux. I looked at the partition structure with fdisk and got the filesystem info below. I knew they were using the QNX operating system, but was hoping they were using an ext2 or ext3 filesystem. This appears to not be the case. I took a snapshot of the image on the drive, and am going to build a linux live CD that will read the qnx filesystem type so I can look around at the structure of it. I will post more info when I do.
Device Start End Blocks Id System
/dev/hda1 1 1211 9727326 4d QNX4.x
/dev/hda2 1212 250 313267+ 4e QNX4.x 2nd part
/dev/hda3 1251 1263 104422+ 4f QNX4.x 3rd part
/dev/hda4 1264 3654 19205707 50 OnTrack DM
