2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
code p0700
Old Dec 5, 2009 | 01:44 PM
raydar86's Avatar
raydar86
Default code p0700
Hello I,m new to this sight. Has any body had this code. from wat I found so far its a seloniod in the tranny. Any info would be veray apreciated.
Old Dec 6, 2009 | 07:24 PM
RobertR's Avatar
RobertR
Found this on *********.com. Hope it helps.
Your P0700 code needs to be addressed right away. This signifies a problem with the solenoid pack, which is an external part that can be fixed for around $200 if you do it yourself, $300 if you take it somewhere. But a bad solenoid pack can mess up the whole tranny resulting in a total rebuild, which runs anywhere from $1200 to $2000 depending on where you go.
