2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2009 Avenger Stuck in Park
Old Oct 3, 2010 | 06:35 AM
JTS27's Avatar
JTS27
Default 2009 Avenger Stuck in Park
I see the postings for resolution for the 2008 Avenger stuck in park with the faulty plastic housing and spring assembly, is this the same issue for the 2009? I am in the same situation but unsure if it is as simple as this spring assembly or possibly a park solenoid.
Old Sep 7, 2013 | 02:39 PM
JefferyBodeen's Avatar
JefferyBodeen
Default stuck in park
yea pull the chrome ring off the shifter then pull the grey plate up and look on the right hand side of shifter .you will see a pink latch mess with it and ya got clip it up with gatorclip never had another problem with it bein stuck in gear.
