2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
passenger side low beam dosnt work 2008 avenger
Old Dec 4, 2010 | 04:53 PM
alexandergabriel72's Avatar
alexandergabriel72
Default passenger side low beam dosnt work 2008 avenger
my 2008 avenger was recently in an auto collission. it has since been repaired. the front passenger side was damaged and the whole head light system on passenger side has been replaced. when we got car back lights worked fine. second day low beam went out.driverside works and both high beams work i ve replaced both low beam bulbs and still nothing. can any one help?
Old Dec 5, 2010 | 09:03 AM
festerw's Avatar
festerw
All lights are controlled through the TIPM, it will shut down the feed to a light if it detects a short. You can try disconnecting the battery to try resetting it but you may need to go to the dealer if that doesn't work.
Old Dec 11, 2010 | 09:47 PM
dogthenine's Avatar
dogthenine
We just bought a 08 Avenger and the bright lights went out, we took it to the dealership and it turned out the be the fuse block under the hood. They had to replace the block and reprogram it, now they work fine.
