2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
missfire
Old Aug 18, 2011 | 09:12 PM
joelcruz123's Avatar
joelcruz123
Default missfire
i have a 2008 dodge avenger se and it has rough idling turns off when it is in park or drive i took it to auto zone and they told my cylinder 3 and 4 missfire. the code was p0303 and p0304 i changed the ignition coil on 3 and 4 but it didnt work help
Old Aug 22, 2011 | 07:47 PM
steak59's Avatar
steak59
A dead miss on cyln 3 and 4? and coil has been replaced?
On these newer GMAC world engine, usually a Dead mis I've seen is the internal engine problem. (usually result from lack of maintainence, these engine are reliable, but very unforgiving about oil change interval)
rent a a Compression gauge and check compression on all cylinder. If it is all good, at least you rule out the worst case scenario. If it is bad, it probably thru a rod or seized oil rings.
