2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Heater is out of control.
Old Dec 15, 2012 | 05:58 PM
avenjeeperger's Avatar
avenjeeperger
Default Heater is out of control.
I'm a new 09 Avenger owner. Here's the background,
Just had the thermostat housing changed, Coolant is full, no trapped air. 100% certain.
Heat goes from hot to cold at random and changes when it wants. I can't change whether it's defrost or floor.
I've read there are ways to test/reset the blend doors etc. can someone give me a clue or two? Thanks!
Old Dec 15, 2012 | 07:46 PM
go-part's Avatar
go-part
Former Vendor
Check your heater control valve, turn the heat up to high and feel the hoses connected to the valve. If only one side is hot, then you need to replace the heater control valve.
Old Dec 15, 2012 | 07:53 PM
avenjeeperger
Yep, both are hot. It seems to be the HVAC control. I'll get a blast of cold air, then it will switch to all cold. When that happens I can't change from defrost to floor or vent. It's stuck where it is. Some times it only lasts a few minutes but yesterday it was that way for 45 miles. My wife was NOT happy. I stopped at AZ to get codes but their scanner doesn't do those.
Old Dec 19, 2012 | 12:59 PM
beezer86's Avatar
beezer86
sounds like the control...but could possibly be a door or actuator problem...the problem with these newer cars is that more and more are using "can" communication where instead of having voltages and grounds you get communication between the different modules in the car on data lines by means of pulses so it will most likely be a dealership job to diagnose...
Old Dec 19, 2012 | 01:42 PM
avenjeeperger
Talked to the stealership today and a scan is $85. She ruled out the blend door actuator as it's not cold on one side it's both. Soooo I think I'll put the $85 toward a heater control.
Old Dec 29, 2012 | 02:48 PM
avenjeeperger
Popped for a new heater control. All is well now. I've seen some core charges on other sites. Anybody know of a place that buys them?
