2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
avenger code p0700 and p1775
Old May 5, 2013 | 09:53 AM
sarmdcom's Avatar
sarmdcom
Unhappy avenger code p0700 and p1775
(Hi I am from Iraq and I'm not sure our maintenance centers where they do not have the experience that you have. So please help me to reach a solution to my problem with the car (dodge avenger 2008).
The problem in my car is when examined connected to the examination show me the following code:
P0700 trans control sys malfunotion
P1775 manufacturer contrl transmission
and
I/M monitors
Htd catalyst N/a
A/C Refris mon N/a
EGR system mon N/a
So please help me and explain these codes is it serious lead to other breakdowns and how is it treated Is it possible Llano I do it myself at home, and if there were video clips showing the solution will be your thankful
Note: that I've reset work for the above failures appear after my use of the car within the city for several days
Old May 5, 2013 | 04:11 PM
steak59's Avatar
steak59
These are Transmission code. You need an Chrysler enhanced scanner to pull more codes off the Trans Controller, and go from there.
A Generic OBD2 scanner has reached it's limit, so you need to go to more equipped shop.
Old May 5, 2013 | 07:50 PM
sarmdcom's Avatar
sarmdcom
Question Is this the correct step?
Today I've opened all of the electrical connections that linked transmission and cleaned by spray and I will test the car tomorrow.
I hope to find a solution to the problem .gentlemen members because I'm sure if I have gone to maintenance centers they Unable fix the problem .
Old May 6, 2013 | 03:51 PM
sarmdcom's Avatar
sarmdcom
Default back to the previous situation above what is the solution
The car worked well without problems for half a day and the only one in the evening returned code appears again and we go back to the previous situation above what is the solution
Old May 6, 2013 | 04:36 PM
bad venge's Avatar
bad venge
Section Moderator
AGAIN, You need a high level scanner to get the code from the Tranny module the OBDII Just CANNOT get the code from the TCM. You can have a bad sensor improper ratio code , we can guess all day long and may or may not fix it...
Old May 7, 2013 | 03:27 AM
sarmdcom's Avatar
sarmdcom
Well I will try to check the car and come back to you
Thank you all
Old Sep 2, 2013 | 11:38 AM
sarmdcom's Avatar
sarmdcom
Default p700 hs ok now
I just you change Hidrelik Automatic Transmission specified in the maintenance manual ِATF+4 and finally disappeared The problem And everything returned to normal work and thank you to all those who tried to help me.
