2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
MIL light is on
Old Oct 1, 2013 | 06:51 PM
mellyvision's Avatar
mellyvision
Default MIL light is on
Hello everyone
Sorry, I have already posted this but I think I put it in the wrong place. :-(
I purchased a 2009 Avenger STX with 64k miles on it around 9 months ago.
It's great, I love it.
Around a month ago the MIL light came on so I checked in the handbook to see what the problem was.
It mentioned "loose gas cap" as one possibility and "poor grade fuel" as another.
The gas cap was indeed not properly fitted, the plastic wire that connects it had become trapped underneath.
I thought I'd solved it.
Sadly not, the light stayed on while I drove it around for a few days.
I took it to my local shop, they replaced the sensor and cleaned out the intake manifold.
The light stayed off for a few days and then came on again.
I ran the fuel really low and bought gas at a different filling station.
I drove for 50 miles then the light went off..... for a day.
The code I'm getting (according to the shop) is as follows:
P2017 Intake Manifold Runner Position Sensor Circuit High
I'm going to take it back for them to have another look at it next week but wondered if any of you guys had any suggestions as to what the problem may actually be?
Many thanks in advance
Melly
Old Oct 1, 2013 | 08:34 PM
steak59's Avatar
steak59
You need to replace the Intake Manifold, and update PCM software. for code P2017
Oh yeah, they are covered under Powertrain warranty. And I think your car should have 5 yr 100k miles warranty. Check with your dealer.
Old Oct 6, 2013 | 06:13 PM
mellyvision
Hiya steak59
Thanks for the reply and my apologies for not responding sooner.
You suggest replacing the manifold completely. Does this mean that the code leads you to think that the manifold may be damaged in some way?
Also, by updating the software do you mean have the code reset (my local shop can do this) or is this something that needs to be downloaded to the car and can only be done by a Dodge dealer?
Thanks for your time
melly
Old Oct 6, 2013 | 08:06 PM
steak59's Avatar
steak59
Originally Posted by mellyvision
Hiya steak59
melly
There is a TSB on this case, and I believe the shaft inside the intake manifold broke off.
Software update can only be done with the right equipment. All dealers have them. SOME independent shops would buy such equipment. But I can not tell you with one does and doesn't, you have to call them and ask if they have a Chrysler factory scanner or a J2534 programmer for Chrysler.
I am not sure what exactly the update does, but maybe it is programing the computer to reduce the torque so it doesn't break the shaft in the future?
Have you check with your dealer on your powertrain warranty?
Old Oct 9, 2013 | 07:21 PM
mellyvision
I've called them and they said it could be covered by the power train warranty, depending on what it actually is that's wrong.
I've just got to sort out a time when I can take it to them as it's quite a drive.
Pardon my ignorance but what is a TSB?
Old Oct 9, 2013 | 08:31 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Technical Service Bulletin. Adendums inserted into the dealer service information as repeated common issues are discovered in the field.
Old Oct 20, 2013 | 10:28 AM
mellyvision
Well, it's sorted and you were exactly right. Many thanks
Sadly the car only had a 3 year power train warranty so it ended up costing me $650 :-(
