2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Can I connect a 2pin motor to 6pin harness??
Old Oct 6, 2015 | 03:52 PM
KimmyMac13's Avatar
KimmyMac13
Default Can I connect a 2pin motor to 6pin harness??
Hi,
I just picked up the whole power window setup -window regulator/motor all attached to the inside panel. My problem is they got me a TWO pin motor but I have a SIX pin harness.
Can I use that motor? I realize if the answer is yes, I won't be able to control the passenger window from the drivers side...but my question is how do I wire he current attached motor to my existing harness?
The motor has two thick red wires...not sure which ones I connect fro. My harness to hose wires.
Thanks in advance!
Kim
Old Oct 7, 2015 | 08:57 AM
Gonna have to grab a wiring diagram from somewhere. Perhaps google for it, or pick up a Haynes manual with wiring diagrams.
Old Oct 11, 2015 | 12:18 PM
KimmyMac13's Avatar
KimmyMac13
Thank you. I went to a Dodge dealer. They said it would not be an issue to just take out the motor and out a new 6 pin one in. I was worried that changing it out would affect the tension on the regulator. It was not an issue. The window is all fixed.
Now I need to find out info on the location of the input and output vehicle sensors....agsin, no info on YouTube or internet on replacing these either lol.
