2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Avenger not starting
Old Aug 5, 2017 | 05:03 AM
Seymour Leonard's Avatar
Seymour Leonard
Default Avenger not starting
I have an 08 Avenger SXT. It completely shut off on me while driving one day and wouldn't do anything else. After getting car towed, found out a 10 amp fuse for ABS/PCM, etc was blown. It started, then blew the 10 amp when i tried to restart. Same thing with a 15amp. Put a 30 amp in and all was good... Check engine light stayed off for sev days till it cane back on... Took it to AutoZone, they gave a P0430 CODE in regards to the bank 2 Catalyst (2/1) efficiency being below normal. Ran for a few more days with no problem, then wouldn't start. Starter kicking in But not turning over. Can feel slight repeating push when trying to start. Any thoughts?
