2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
overheating
Old Sep 21, 2017 | 03:29 PM
Isaacsgirl15's Avatar
Isaacsgirl15
Default overheating
I have a 2011 Dodge Avenger Lux, replaced thermostat and heater core, but car still runs hot
Old Sep 21, 2017 | 03:51 PM
Engine? Mileage? Always done this? Just started? Why did you replace the heater core? Probably the radiator needs to be flushed. Proper mix of coolant in it? Water pump been checked? More info is needed please so we don't keep have to asking you questions.
Old Sep 21, 2017 | 04:25 PM
Isaacsgirl15
[QUOTE=jkeaton;3358808]Engine? Mileage? Always done this? Just started? Why did you replace the heater core? Probably the radiator needs to be flushed. Proper mix of coolant in it? Water pump been checked? More info is needed please so we don't keep have to asking you questions.[/QU
Six cylinder engine, mileage 148,000, Replaced heater core because car was running hot and radiator smelled hot coming through vents when driving. I no longer smell this. Started about two months ago, had radiator flushed and thermostat replaced, just had heater core replaced two days ago. Water is circulating, so I thought water pump was good.
Old Sep 21, 2017 | 05:31 PM
Cooling fans operational?
