2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2012 Avenger Trans oil cooler line leak
Old Jan 25, 2018 | 09:29 PM
Taiman's Avatar
Taiman
Question 2012 Avenger Trans oil cooler line leak
i discovered today that my Trans oil cooler lines are leaking. It is on a 2012 Dodge Avenger 3.6 L. It looks like the line wrap around the front of the radiator and would be a lot of time to get them out. Any ideas on a procedure to fix them?
Old Feb 2, 2018 | 09:52 AM
primem's Avatar
primem
how bad is the leak? if its a seep that forms is very cold weather only; leave it. if its forming drops of fluid; fix it. line replacement is the best bet. any quick fix of cutting the line, flaring and hose clamping it never work for long.
