2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Right front turn signal inop. not bulb
Old Apr 25, 2019 | 11:24 AM
beech2000's Avatar
beech2000
Default Right front turn signal inop. not bulb
I thought lamp bulb was bad so replaced with a new one. Same rapid right turn signal, light still won't illuminate along with the lamp out ding. Bad bulb again? nope. Verified 1st lamp and new lamp good when installed in left side. Performed ground check and found good. (.002 ohms to ground). Power problem. Is there a fuse alone for right side marker lamps?
vehicle is a 2013 Avenger 4 door with the 4 banger engine.
Last edited by beech2000; Apr 25, 2019 at 11:25 AM. Reason: To include model and year of vehicle
