2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
1500 leaf spring and coil spring swap to dakota slt
Old Feb 22, 2014 | 07:36 PM
Obie619's Avatar
Obie619
Default 1500 leaf spring and coil spring swap to dakota slt
Hi I'm new. I wanna know if I could put ram 1500 leaf springs and coil shocks on 2000 dodge dakota slt ext cab.
Old Feb 23, 2014 | 05:33 PM
hanleysh's Avatar
hanleysh
Is your truck 2wd or 4wd?
Old Feb 23, 2014 | 05:41 PM
hanleysh's Avatar
hanleysh
Either way I'm going to guess they will not just interchange....There will likely be extensive fabrication required
Old Feb 23, 2014 | 07:28 PM
Obie619's Avatar
Obie619
It's a 4 wheel drive truck. I've done some work to it but want suggestions on homemade lifts
Old Feb 24, 2014 | 10:47 AM
hanleysh's Avatar
hanleysh
Your truck has a torsion bar set up for the front which means no coils up front right now. As far as a home made lift....you could do a SAS (solid axle swap) for the front. Or make yourself drop brackets for the control arms, diff, etc. Or since your trucks a 2000 their are companies that make lift kits for it.
