2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
Why can't the factory look this clean?
Old Jan 2, 2015 | 07:31 PM
magnethead's Avatar
magnethead
Default Why can't the factory look this clean?
Mike Murray just put his stock eliminator motor in his truck. Man it looks clean without the PDC and battery. Maybe it's because the truck is white. Interior is nicely done too, per class rules, all trim and seats must stay in place.
Old Jan 2, 2015 | 07:47 PM
00DakDan's Avatar
00DakDan
Section Moderator
It does look clean. What's he run?
Moved to "general discussion"
Old Jan 3, 2015 | 03:07 AM
magnethead's Avatar
magnethead
His bracket racing basically stock 360 ran 8.20's I think in the 1/8. That motor there is his tricked out stock eliminator motor- said it's almost 500 HP with the class-required stock bore and stroke (must be factory stroke, they allow up to 30 over on the bore). Everything has to be factory available (In our case, Mopar Performance) and be numbers matching to the truck's generation, and the heads may not be machined- must be out of the box stock. I/CM is a 7.85 and 12.10 index, 1/8 and 1/4 respectively, minimum weight 3800 pounds with full factory interior, body panels, and chassis in place (AKA no cutting the bed floor out or backhalving the chassis).
Old Jan 5, 2015 | 02:03 PM
Josh17's Avatar
Josh17
Very cool.
Old Jan 8, 2015 | 02:15 PM
Trapper723's Avatar
Trapper723
That's a very clean truck. You have anymore plans for your 3.9 project this year, magnethead?
Old Jan 8, 2015 | 07:29 PM
magnethead's Avatar
magnethead
depends on how empty I want my bank account. All I can say is "stay tuned".
