2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
2002 dakota clutch recommendations
Old Jan 7, 2025 | 10:15 PM
ORiley's Avatar
ORiley
Default 2002 dakota clutch recommendations
Hey yall I'm trying to determine what clutch would be best to replace my grandfather's 2002 dakota sxt 3.9 200,000 miles
From my own research I should be looking for a full disc Kevlar for longest lifespan but I'm looking for some recommendations from others with more experience.
more information - stock nothings been done to it all original throwout bearing just went out after 20+ years but I figured might aswell replace clutch and everything when while I'm down there. Little use weekly might tow the occasional side by side on weekends.
Old Jan 21, 2025 | 12:30 PM
dodgetruck2's Avatar
dodgetruck2
If the truck is stock, and not looking to do any modifications. I would just find a good OEM replacement. Kevlar clutch's could prove to be more grabby, not as bad as ceramic but worse than organic. Luk sells a nice clutch through napa, should be able to specify organic facing. The oem made 200k? what are the odds it needs to survive another 200k
