rear end swap
Old Mar 30, 2007 | 05:38 PM
dpoliver's Avatar
dpoliver
Default rear end swap
Dug into my differential in the fall...was getting alot of whine..
had the pinion bearing changed....
but the housing was a little gouged..
repair has lasted till now...whine is coming back...
want to swap out the entire rear end with a donated one...
mines a 8.25 10 bolt with 3.55 gears...open diff
would like to upgrade to lim slip...
are they available in the 8.25 or does it have to be 9.25...
would it mount right up to my axle..no mods..
should i be looking for an r/t or durango...would a 4x4 rear end work...
any thoughts..?
Old Mar 30, 2007 | 09:20 PM
wink2873's Avatar
wink2873
Default RE: rear end swap
i think only the 9.25 had limited slip. you could get another 8.25 and put a locker or an auburn liimited slip differential in it.
Old Mar 31, 2007 | 04:12 AM
horatio102's Avatar
horatio102
There's another thread talking about this - ring gear size has nothing to do with what ratio or type of differential installed. LSD was an option offered on both the 8.25 and the 9.25 axles. The 9.25 is a stronger axle, but you may not need the extra weight and strength. I'd recommend going with the 3.92 ratio though, it'll give you a bit more pickup and make hauling loads easier. 2wd versus a 4wd axle may not matter, but I don't know. The angle of the spring perches might be different to correct pinion angles due to the 4x4 possibly being higher
Old Mar 31, 2007 | 10:36 PM
dpoliver's Avatar
dpoliver
I like the ratio of the 3.55...highway vs get up and go...
but my true question is whether or not the 9.25 will bolt right up...
or should I keep loking for a 8.25...
seems much easier to replace the entire rear end...
that's why I wanted to know what junked vehicle would be a match...other than a 01 dakota sport...
and with the lim slip
thx
Old Apr 1, 2007 | 03:07 PM
jonnymagnum's Avatar
jonnymagnum
either a 8.25 or a 9.25 will bolt right up.
Old Apr 1, 2007 | 10:51 PM
dpoliver's Avatar
dpoliver
Awesome...
didn't want to change drive shafts or fiddle with the
geometry or anything...
leaf springs and mounts all the same...
9.25 just beefie er...
