bad cat?
Old Mar 31, 2007 | 11:19 PM
boohoops's Avatar
boohoops
Default bad cat?
my cat rattles at low speed/rpms. ive heard that not all rattlin cats are bad, but i want to know for sure.
Old Mar 31, 2007 | 11:33 PM
imnothot02's Avatar
imnothot02
Default RE: bad cat?
waht kinda mpg ya gettin...ull knowby that that is the easiest
Old Mar 31, 2007 | 11:36 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
mine does the same thing but around 2000 RPM and my gas mileage is fine its right around 16 sometimes a little lower depending on how i feel like driving that tank or the winter gas and other factors
Old Apr 1, 2007 | 12:00 AM
boohoops's Avatar
boohoops
well seeing how i got a 5.9L, i get about 9 around town. (sucks but thats wat u get for havin a kicka$$ r/t)
Old Apr 4, 2007 | 07:17 PM
boohoops's Avatar
boohoops
so if it ratlles and i hav average milage, duz it still need to be replace?
Old Apr 5, 2007 | 01:46 AM
imnothot02's Avatar
imnothot02
you should get atleast 12.... and the cat can be checked...hit it lightly with a dead blow and see if it sounds like a bunch of rocks in there if so replace it...
Old Apr 5, 2007 | 05:03 AM
User's Avatar
User
ORIGINAL: boohoops
lol.. thats not normal. 12city - 17highway is normal.. for a stock 5.9
i have a some stuff done to mine and i dont even get 9mpg. I get about 14 avg.
You should check your o2s also. having bad o2s can also f-up your cat. You should have ine right before the cat and one right after, very easy to take off anc check..
Also if you replace the cat, a highflow cat is good, but somtimes you may have to replace the sensors with a aftermarket brand, due to the factory sensors only working under factory cats flows.
or you can also get a o2 SIMM Fastman sells them, you buy one and it replaces your rear o2 sensor with a computer that tells your pcu you have a perfect flowing cat.
Old Apr 5, 2007 | 11:52 PM
batman13's Avatar
batman13
make sure it's not the exaust banging against the frame,
I had this problem when i got the truck, One of the front hangers broke and at low speed accel. it banged around and sounded like sh*t
Old Apr 5, 2007 | 11:53 PM
boohoops's Avatar
boohoops
yeh today i brought it into my auto class. i hit it and it sounded like loose debris inside. i also checked the temp on both ends. it was a lot warmer on th inlet side than th outlet side. so it seems as tho im gonna need to replace it.thanks
Old Apr 6, 2007 | 12:32 AM
imnothot02's Avatar
imnothot02
yea, be carefully not to breathe the **** that falls out of it...whear a mask or something, well this is what Ive been told...
