Pinhole leak
Old Apr 5, 2007 | 08:16 PM
clubber's Avatar
clubber
Default Pinhole leak
I found a pinhole leak in the block by the lower thermostat. it started leaking coolant yesterday, hasn't leaked any today. What should i do?
Old Apr 5, 2007 | 09:41 PM
f0x672's Avatar
f0x672
Default RE: Pinhole leak
id wait and keep checking it periodically, it will get worse and then it will have to be fixed, so just take it easy on her.. now is it in the actual blow or where a component mates with the block cause normally a blow would crack, sounds like a a seal problem at the thermostat housing
Old Apr 5, 2007 | 10:21 PM
imnothot02's Avatar
imnothot02
more info..?
but you should fix it...
Old Apr 5, 2007 | 11:33 PM
clubber's Avatar
clubber
its in the block. i saw it shootin out like a little spray. it looks like a rock skipped up and hit it. i just need some info on a good way to seal it.
Old Apr 5, 2007 | 11:41 PM
batman13's Avatar
batman13
i'd find somebody with a welder, a tack in the spot would seal it good
