code P0442
Old Apr 13, 2007 | 02:01 AM
f0x672's Avatar
f0x672
Default code P0442
P0442 (M) Evap Leak Monitor Meduim Leak Detected A small leak has been detected in the evaportive sysem.. my buddy is picking up his dakota down in florida and is wondering what would cause this?.. thanks
Old Apr 13, 2007 | 12:01 PM
imnothot02's Avatar
imnothot02
Default RE: code P0442
do a gas cap change first, check all ur hoses smoke it if you have access to the equptment...
Old Apr 13, 2007 | 09:46 PM
red9535's Avatar
red9535
Its almost defintely the gas cap. Take it off, then put it back on and tighten it so it clicks a few times.. reset the code. If it comes back, check your hoses and stuff.
Old Apr 13, 2007 | 11:02 PM
imnothot02's Avatar
imnothot02
^^^ what was the point of that post?
Old Apr 16, 2007 | 05:50 PM
f0x672's Avatar
f0x672
aright... well. my friend reinstaled the gas cap, and reset the code, and after the 1300 mile trip home from florida, the cel came back on, and now he noticed how the gas cap has a little play in it when he moves it back and forth.. hes goin to replace the gas cap, and he inspected the lines
Old Apr 26, 2007 | 11:53 PM
Ryknow86's Avatar
Ryknow86
If the gas cap still doesnt fix it, theres a bunch of things that could be wrong. Lines, charcoal canister, purge soleniod, vent soleniod... the best way to diagnose it would be with a scanner anda smoke machine.
Old Apr 27, 2007 | 01:02 AM
f0x672's Avatar
f0x672
o yea i know all the possible problems, plus it was solved, the line from the pressure test pump to the charcoal canister was dry rotted at the pump, 6 inches of new hose and a male-male adapter.. all good
