code 420 and 432 Dakota
Need IDEAS: 2001 Dodge Dakota V6 (96,000 miles) - My MIL light is on, has been on. Took truck to have code read. Indicated 420 and 432 catalyst problem. I was told it may also be the MAP sensor. Checked MAP sensor, it is functioning properly. Where do I go next? OX sensors? Catalytic converter? Any idea of something else? Thanks!
Welcome to the forum.
I can not help you out with you codes, but if you post in your generation section you will get alot more replies and alot better help. This section is set more for just saying hi. Good Luck.
