lh turn signal intermittant
Old May 8, 2007 | 05:05 AM
rasb70's Avatar
rasb70
Default lh turn signal intermittant
lh turn signal has a mind of its own when it doesn't work there is no rear flash and the front flashes like crazy fuses are fine and changed the bulbs out any suggestions???
Old May 8, 2007 | 02:32 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: lh turn signal intermittant
it could be your flasher relay. but if you have a bulb out, then the other one will flash like crazy.
I had one of my front turnsignal bulbs go out, and they flashed like crazy, but it took a while to find it since both of them still flashed. its hard to tell in the day light.
