Squeaky Clutch Pedal
Old May 31, 2007 | 11:17 PM
TheePlaymaker's Avatar
TheePlaymaker
Default Squeaky Clutch Pedal
So today it was pretty hot probably high 80's and i had to drive about an hour around some pretty congested traffic. The truck started running right below the 210 line tempurature wise which didn't really bother me seeing how hot it was and it was in lots of traffic but after a while it started shifting really hard and the clutch pedal started to squeak when u pushed it in and out. Just wondering if i should have the garage lube something like the linkage or something next week when it goes in for shocks and tranny fluid change and if its just the heat causing the squeaking. When i left it didn't do it the whole way home which was mostly high way and the temp never climbed to where it was on the way there.
Old Jun 1, 2007 | 03:31 AM
98R/TDak's Avatar
98R/TDak
Default RE: Squeaky Clutch Pedal
probably just from over usage of that day,is it still hard to shift? if it is then i would check the tranny fluid or clutch fluid if it has it im not sure if it does...my brake pedal does the same thing
Old Jul 9, 2008 | 06:36 PM
TheePlaymaker
so guys i took a video of this annoying squeaking noise in my clutch pedal in hopes that someone can lead me in the right direction to get it fixed i'd prefer to do the work my self to save labor but i dont knwo what it is for sure so i dont wanna go spending money and not fix my problem heres the clip any help would be greatly appreciated
http://youtube.com/watch?v=Kd8snlIR43o
