Tranny fluid
Old Jun 15, 2007 | 08:19 AM
cbassj8's Avatar
cbassj8
Default Tranny fluid
I have a question about changing the transmission fluid on a 01 dakota 4.7, How much Tranny fluid is needed if I drop the transmission pan and change the filter. Thanks for any help I can get
Old Jun 15, 2007 | 02:36 PM
Chris's Avatar
Chris
Default RE: Tranny fluid
It all depends, as the amount of fluid you dropped can vary from others. The best way to do it is to drop the pan, replace the pan, start the truck for (while it is cold) and cycle through the gears quickly. Drop the pan again to get the remaining fluid out, change the filter. Refill the tranny fluid with about 3 quarts. Start the truck and cycle through the gears. Use the instructions on your tranny dipstick for topping it off to the correct level.
