3.9 engine and water?
Old Sep 28, 2004 | 10:17 PM
MAGNUMR/T-Z06's Avatar
MAGNUMR/T-Z06
Default 3.9 engine and water?
I just came thru a heavy rain with local street flooding. The Dakota died!!!
What on or around the engine on the 3.9's commonly gets wet enough to kill the engine!!The truck is a 2000 model year.
Old Oct 18, 2006 | 01:34 PM
Erich_121's Avatar
Erich_121
Default RE: 3.9 engine and water?
just died completly? thats werid. IF you got water in your intake to the engine it would sputter then die. Id be checking for other problems
Old Oct 18, 2006 | 02:06 PM
Chris's Avatar
Chris
you probably got water on the distributor cap. did it just die? did it sputter? check to see if there is moisture on or around your distributor cap.
Old Oct 18, 2006 | 04:19 PM
tntitans21399's Avatar
tntitans21399
How rain were you going through? As long as your hood was down and not driving through a river the rain fall shouldn't have down anything. I would be looking about to make sure it's not anything else that is major. Does the engine crank when you try to start it? If it doesn't do anything then I would first check your battery. Maybe your alternator went out and wasn't charging the battery and then you ran out of juice in the battery.
Old Oct 18, 2006 | 06:01 PM
f0x672's Avatar
f0x672
mentioned before that moisture at the distributor... but also... it could of been pure coincidence and the distributor just died... happened to me in a 95' chrysler cirrus.... just going down route 80.. 75... next thing i know.... engine is sputtering.... dead
Old Oct 18, 2006 | 06:21 PM
RP Racing940's Avatar
RP Racing940
Coil is in a area that it could had got hit hard enough by spray to pop the coil wire off. But Take the distributor cap off, spray wd40 all over the inside of the cap and rotor and reassemble. Check the cap for cracks before you put it back on though.
Old Oct 20, 2006 | 01:29 AM
BlackDak07's Avatar
BlackDak07
check your crank shaft position sensor. it right by the block and the tranny....i had the same problem..my truck had a bad misfire in the rain..when it was dry it ran like a champ. $97 for the sensor and it was fixed
Old Oct 20, 2006 | 01:59 PM
Chris's Avatar
Chris
ORIGINAL: BlackDak07
+1! good thinking!
