Dakota Help Please
Old Sep 28, 2004 | 11:47 PM
Gunny's Avatar
Gunny
Default Dakota Help Please
My son has a 2000 Dakota 2wd 3.9l. The turn signals as well as the emeregncy flashers do not work. No dash indicator arrows no nothing. All bulbs are good. I assume it is a flasher problem but am having a hell of a time finding it. Does this sound as if it might be the problem? Everything seems to be in working order. The turn signal clicks both ways and the emergency flasher button works ok.
Old Sep 29, 2004 | 06:10 AM
ct4x4's Avatar
ct4x4
Default RE: Dakota Help Please
have you checked both fuse boxes? this happened to my dakota and it turned out to be the fuses
Old Oct 19, 2004 | 10:05 PM
CYCLONE_06's Avatar
CYCLONE_06
I agree, sounds like a fuse definately. Check the box. Its under the hood, should be on the drivers side.
~CYCLONE_06
Old Jan 6, 2005 | 10:37 PM
98dakotalikenew's Avatar
98dakotalikenew
I am new to the dodge line but in my old gmc it was the flasher relay under the dash on the drivers' side. you might try checking all the relays anyway.
