Co-Workers Dakota check engine light
Old Sep 29, 2004 | 02:24 PM
Dosborn's Avatar
Dosborn
Default Co-Workers Dakota check engine light
Good morning. My co-worker has a 1999 doge Dakota. Her check engine light came on last night so I told her I would try to pull the code for her this morning. Well I can't seem to pull the code. I have tried the two methods I have found on various sites to try to pull the code.
#1, hold the reset button, turn the car to on, then release the button. No result.
#2 Turn the key from On to Off to On to Off then to On one more time. Tried this about 20-30 times no result each time.
What am I doing wrong? Thank you for your time.
- Dana
Old Oct 4, 2004 | 12:04 AM
kota98's Avatar
kota98
Default RE: Co-Workers Dakota check engine light
you need to retreive the codes by an external code scaner 97 i believe was the last year for the on board code scanner for the dakotas
Rick
Old Oct 21, 2004 | 01:16 AM
southeastperformance's Avatar
yup, thats true. 98-99 models have an external scanner to plug under the dash for code readings. you can try Autozone stores or some other parts stores in your area to see if they will read the codes "free" for you. some do that thinking you will be buying the new parts from them.
Old Nov 4, 2004 | 02:14 AM
HEMI ?'s Avatar
HEMI ?
if it runs fine i might say chck the gas cap alot of cars have the vacume system on them and if a crack is on the oring for the cap it allows aleak and blammo check engine light not sure if it applies to your year but i know it applies to alot of dchryslers stuff
good luck
