Grease Fittings?
Old Jun 25, 2007 | 08:20 PM
2002Dakota4.7L's Avatar
2002Dakota4.7L
Default Grease Fittings?
Well I was poking around the dak today and noticed that I didnt see any grease fittings. I am particularly having an annoying squeek when I run the truck first thing in the AM get down the road a couple miles and the suspension stops squeeking. Kinda sounds like a dry body mount or a rubber bushing on theleaf springsbut I am not sure.
Also I am getting a clunk only with the wheels are turned to just about the lock at a stop and I then begin accellerating, mostly happens when turned left and only 1 clunk/pop sound. Wheels feel tight when I move them to check the ball joints.
Any clues?
Are there any grease fittings that need to get greased?
Old Jun 25, 2007 | 08:52 PM
ptrapper65's Avatar
ptrapper65
Default RE: Grease Fittings?
the stock ball joints and tierod ends don't have grease fittings. Hence, the reason I'm replacing them at 80k
Old Jun 25, 2007 | 09:05 PM
f0x672's Avatar
f0x672
yea i haven't noticed any fittings on the dakota at all.. and that squeak just sounds like a dried out bushing... and for the clunk,. check your u-joints on your driveshaft, could only be acting up when you put a steering load onto the rear differential ( when you turn your wheels while moving, the inside wheel of the turn, spins slower then the outside wheel)
Old Jun 25, 2007 | 11:39 PM
2002Dakota4.7L
Any sort of grease recommended? White lithium or WD-40?
The clunk seems to be from the front end but like I said everything seems to be tight. Truck goes in for its annual inspection next month I will have the tech's check it out. They are strict around these parts.
Old Jun 26, 2007 | 01:49 AM
f0x672's Avatar
f0x672
from what i know, has to be replaced for the squeak to go away, u can always spray some wd-40 for a quick, temporary fix
