evap emission leak . . . HELP
Old Jul 18, 2007 | 08:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default evap emission leak . . . HELP
ok guys, heres the story, my dads 03 dakota qc 4x4 w/ 3.9l v6 has started throwing cel codes p0455(Evap Emission contol system leak[large])and p0442 (Evap Emission contol system leak[small]), and we keep turning it off(we have a code reader for the OBDII systems) and cannot figure out whats causing it any help or suggestions would be appreciated
oh by the way, he already went out and bought a new gas cap for the truck and it hasnt changed the problem, i need other ideas thanks
Old Jul 19, 2007 | 08:27 AM
shrpshtr325
THE ULTI-MOD
Default RE: evap emission leak . . . HELP
can anyone help, any ideas at all we're willing to try anything to fix the problem PLEASE HELP US
Old Jul 19, 2007 | 10:22 AM
mplue's Avatar
mplue
I had the same thing on my 03 QC 4x2 4.7l V8. I found two rubber hoses that were cracked, quite severely on mine, that I replaced. I'll tell you where I looked on my 4.7l, not sure if it's the same for the V6. One hose connected to the throttle body on the drivers side. Right where the hose slipped over the connector was cracked all the way around. That hose runs under the fuse box and to a sensor right next to the battery. I replaced the whole hose, but found out later that you can pull the hose off and just cut off the bad part and put it back on. There should be enough slack. The other hose I replaced went to the same sensor and was located just above the exhaust manifold on the drivers side. On my engine, these hoses were zip tied together. I can only assume that they cracked from being near the engine heat and dried out. It only cost a few bucks to buy the hose, don't remember the size right now, it took maybe 15 minutes to fix it. Hope that helps.
Old Jul 19, 2007 | 01:58 PM
Chris's Avatar
Chris
Also check the hoses running to the charcoal box under the bed, near the gas cap area. There are two hoses running in/out. Make sure they have not become rotted out/loose.
Old Jul 20, 2007 | 08:23 AM
shrpshtr325
THE ULTI-MOD
ok thanks i will tell him to check that and let you know what comes up as the problem, if we figure it out thanks, and im still open to more ideas if anybody has them
Old Aug 2, 2007 | 10:15 AM
8795Dakota3.9's Avatar
8795Dakota3.9
I had the small evaporator leak (p0442) and I took it to the local dodge dealer to get them to look at it. They replaced the evaporator for $60, no trouble since!
Old Aug 2, 2007 | 11:57 AM
shrpshtr325
THE ULTI-MOD
actually we found the problem, it was a cracked hose going into the evap solenoid which we just cut back and stuck together again, fixed . . . for now
