Does switching to a 727 affect the computer?
Old Jul 21, 2007 | 03:32 PM
englitrob's Avatar
englitrob
Default Does switching to a 727 affect the computer?
Does the ECM require feedback from the transmission? Can you drop in a 727 and drive away, or does is require a performance chip that will ignore the transmission? I am having repeated problems with the 545rfe in my 03 and I would like to get a bulletproof 727 built for 500+ horses. Also, does the 727 result in less parasitic loss in the drivetrain? Does anyone recomend a rear end gear change with the 727, and would that moderate chnages in fuel ecomony?
[sm=imsmilin.gif]
Old Jul 21, 2007 | 03:34 PM
OneBadKota's Avatar
OneBadKota
Default RE: Does switching to a 727 affect the computer?
If you want fuel economy, you'll want the A-518. (727 with OD) and run about 3.23 gears.
Old Jul 21, 2007 | 11:52 PM
varsis's Avatar
varsis
Well I was looking for an alt for this transmission behind a hemi. I was wondering how these 727 are? or the a-518. I know the a500 is junk
Will the a-518 hold up to 500+ hp stock or does it need to be rebuilt. Right now I am looking into doing a hemi swap. That is why I am asking also the topic is up here.
Old Jul 22, 2007 | 12:32 AM
OneBadKota's Avatar
OneBadKota
A-500s aren't really junk. They can handle up to 500HP.
As for the A-518 doing over 500HP,I would rebuild it and beef it up a little bit with a shift kit.
Old Jul 22, 2007 | 03:19 AM
varsis's Avatar
varsis
Well i sunk my truck got water in and have had nothing but problems. I want to junk the tranny.
http://en.wikipedia.org/wiki/TorqueFlite#A618
There is a detail on some of the trannies. I found a place rebuilding something like the a - 618 to with stand upto 700 hp. I know the a500 is junk. It is weak. It basically a car tranny with od.
Old Jul 22, 2007 | 05:30 AM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: englitrob
[sm=imsmilin.gif]
I don't know about the ECM but a properly built 727 will handle anything the old 426 hemi can give it. It is probably the most bullet proof auto ever made.
Trivia note: Ford tried to buy the rights to build the 727 for there cars.
Old Jul 23, 2007 | 01:59 AM
moe7404's Avatar
moe7404
Moe in Wichita, KS mopar auto trans
I am not a trans expert. This is just what I have learned about mopar trans over the last 40 years
On the older mopars the Trans would not go in reverse when the Trans oil filter was clogged, cold weather made this worse. Why rev. and not forward gears? Because rev. runs the trans. line pressure to 350 psi. forward gears to 100 200 psi. the higher pressure takes more volume of oil that the clogged filter can’t pass. but I don’t know about the newer trans. Also the older trans stops the lube/ cooler line in park so in hot weather don’t sit idling in park. It will over heat and spit oil out the fill tube. And on some cars gets on the ext. pipe and cause a fire. If your older mopar trans bangs real hard going straight to rev. try going to low with the lever, then go rev. it wont bang as hard, remember the pressures? If you look at the trans flow charts you will see that the low/ rev band is on in low gear only if the lever is in low, in drive low gear, they actually call it breakaway, the band is not on, it is always on in rev. But it really needs a low/rev band adj. A trick to get longer life is to put rear end grease in a trans, one or two qts. Two works good in 727s. It will shift better to. I have used this trick on the older trans, 727, 904s with no bad effects. This may or may not work on newer trans. I have put one qt in my 99 Dakota v 6. about 8 mo ago, so far so good. A cooler is ALWAYS a good idea. I have had shift kits in two trans, I think they are good. Just don’t do full race kit on a street trans. If you have a 7 ¼ dia. ring gear rear end don’t make it shift hard going from 1st to 2nd, it will break the spider gears over time. I understand the newer trans have a check valve in the cooler lines. So if one of these trans blows up the check valve will hold junk and keep the fluid from lubing the trans. So the valve needs cleaned after a blowup. Don’t forget these trans have an aluminum case, use anti-seize compound on the bolts and don’t over tighten the bolts.
