Rear Sway Bar Links
Old Jul 25, 2007 | 06:32 PM
DAKNBLK's Avatar
DAKNBLK
Default Rear Sway Bar Links
I finally got tired of the rattling from the rear links and decided it was time to replace the bushings inside the 'dogbones' if possible. This was before I discovered you could buy the entire links, ready to go. Well anyway, I took one off, and the bushings looked fine. Not cracked or torn, and the center hole showed no signs of being out of round.. The real problem looked to be that the bolts were simply loose inside the bushings. Wanting to do, something to help the rattling, I used some really thin aluminum sheet to make shims for the bolts, to bring their diameterup to where they would fit really snug inside the bushing. Long story short... I know this was a klugey thing to do, but the noise is gone, and the rear does seem to stay planted better in turns.[/align]
Old Jul 26, 2007 | 11:27 AM
steve05ram360's Avatar
steve05ram360
Default RE: Rear Sway Bar Links
cool, awesome fix... you can find sleeves at most hardware stores that would have taken up the slop, or you could have bigger bolts to do the same thing.
