Installing trailer brakes in truck
Old Aug 2, 2007 | 01:22 AM
klings designs's Avatar
klings designs
Default Installing trailer brakes in truck
I have a 2004 and I need to install trailer brakes. How about do i do this. I see that on my plug by the tailgate i have a blue wire.. Can i just put a different end on.. But how do i control how much the brakes push?
Old Aug 2, 2007 | 09:11 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: Installing trailer brakes in truck
my moms durango came with a control from the dealer, all we would have to do is install it if we need it so idk we dont tow, but i would have thought that it came w/ a brake controler
Old Aug 2, 2007 | 08:02 PM
DAKNBLK's Avatar
DAKNBLK
Hey, klings, you say you have a plug on the rear, is it the standard 4pin or something else. Since you have a plug there, I assume that you've used it just for trailer lights? Is the plug from a parts store, or OEM Mopar? Does your build sheet indicate that you have the towing pkg. with a brake controller or pre-installed wiring for a brake controller?
Anyway, you'll need an electronicbrake controller (sold at most parts stores, and even Wally World), most likely a 6pin round connector, (but then again, we don't know what plug is on the trailer you'll be pulling), and some 10ga. wire to run from the controller to the battery, and the plug in the back.
We need more input as to just exactly what you already have to work with.
Old Aug 3, 2007 | 12:08 AM
klings designs
Allright, so all i know is that I have a 4 pin in the back. There is a blue wire not connected to it, but i can see it is there for a different end if installed. I know i dont have a brake controller in the front... I am wondering where that blue wire runs too? My boat trailer is going to be a 5 pin rectangle! The only difference is, that the blue wire will be for one of the pins!
Old Aug 3, 2007 | 04:23 AM
horatio102's Avatar
horatio102
5 pin?
:huh:
Sounds like you don't have the tow package installed from the factory. I did, and all I had to do was install the controller in the cab and buy the adapter harness that plugs into the wires under the dash. The hitch side already had a 7-round connector and was ready to go for trailer brakes.
Old Aug 3, 2007 | 08:36 AM
shrpshtr325
THE ULTI-MOD
yup, thats the same way our durango is so idk what to suggest
