electrical question
Old Aug 9, 2007 | 11:08 PM
mmaloney8's Avatar
mmaloney8
Default electrical question
Hello All;
New here and looking for help...
Have a 03 Dak / Quad cab 2wd, the power windows are not working either from the driver control or the individual doors. I've replaced the fuse but still not working. While checking out the windows noticed the wipers aren't working either. Problem just started this week. Checked for codes nothing shows.
Any suggestions of what to look for.
Would the wiper relay be the problem?
Old Aug 10, 2007 | 12:53 AM
dapirate559's Avatar
dapirate559
Default RE: electrical question
is it just the windows and wipers? does the horn work? how about the cd player? if it was me i could check the relay and all the fuses inside and out. if that doesnt solve it then who knows. but for the mean time i will look and see what i can find.
Old Aug 10, 2007 | 08:47 AM
ltl grn dakota's Avatar
ltl grn dakota
first thing to check, is the circuit breaker(25amp) inthe fuse panal. using a volt meter check for power
and ground at the plug for the window switch. passengerswitchs getsits power from the drivers side
i think the power wire is a tan color wire. as for the wipers check the relay in pdc box on driversside fender then check themodule beside the motor itself good hunting
