water in tank?
Old Aug 10, 2007 | 05:18 PM
cynthiaprice's Avatar
cynthiaprice
Default water in tank?
I have an '02 4.7 **** Cab with about 36K miles. Love it.
When I drove it on Sunday I could tell it was missing a bit so I determined to take it to the shop when I next had a chance, on Thursday or Friday. When I drove it on Monday just around town it seemed like it was in low gear and/or that the emergency brake was on -- as soon as I let off the gas it torqued down. I even pulled to the side, shut down and restarted in case something was stuck. No help. After another half-mile it started missing A LOT, like bucking almost, and the brake pedal didn't work right -- there was no give, the brakes were just right up top. That's when I decided to turn back for home. A good idea because about six blocks later gray smoke started coming out from the left front wheel well. That's when I pulled over and called AAA.
Never got any lights or messages. No change in guages. AAA guy said it smelled like transmission. Mechanic says there's nothing wrong mechanically and thinks there was water in the tank. Water in the tank would do all that?
Old Aug 10, 2007 | 11:33 PM
dhvaughan's Avatar
dhvaughan
Default RE: water in tank?
ORIGINAL: cynthiaprice
i think you might need a new mechanic. no, i don't think water in the tank would do all that, especially the gray smoke from the wheel well. could be a stuck brake. water in the tank would just make it skip and stutter and maybe not run at all.
Old Aug 11, 2007 | 12:37 AM
dapirate559's Avatar
dapirate559
ya its probably just something to do with the brakes.
