gear questions
Old Aug 14, 2007 | 06:19 PM
batman13's Avatar
batman13
Default gear questions
what gearing would i look to put in my truck if i'm looking to put heavy wheels/tires on,
while not losing highway capabilities?
my truck has trouble with the 31x10.5s on stock rims i've got
i'd hate to see how it moves 31's on 22's
i currently have the 8.25(?) rearend and a 2.5L engine
Old Aug 14, 2007 | 06:53 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: gear questions
at least a 3.9L in it in order to move it
j/k but if they are the same size around (31's) then it should be about the same either way and wouldnt a higher gear ratio help it move better( better acceleration, for higher rpms at highway speeds??) i think, and what gears do you have now????
Old Aug 15, 2007 | 03:08 PM
jonnymagnum's Avatar
jonnymagnum
I would just get smaller tires[8D] your only 2wd
but i dunno what gears you have now, but 4:10's should be good.
Old Aug 15, 2007 | 06:29 PM
batman13's Avatar
batman13
ORIGINAL: shrpshtr325
i don't remember offhand what gears i've got i think 4:11's?
but the big wheels are a lot heavier(+20-30 lbs) than what i've got now
eventually i'd like to do a small block swap (440 magnum )
