Common Problems
Old Aug 19, 2007 | 05:18 PM
dwhess504's Avatar
dwhess504
Default Common Problems
I may have a small Trans leak, Im trying to figure out the common leaks for the r/t's
It looks the tranny leak is comming from the pan, so could just be the seal. Any one else have
Transmission leaks or rear end leaks??
Old Aug 19, 2007 | 06:14 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Common Problems
I have a rearend leak. my pinion bearing must be bad. you think they woulda replaced that when they rebuilt the rearend last year
but for your tranny leak. its probly just the gasket. you may as well do a tranny fluid change while your down there.
Old Aug 19, 2007 | 06:38 PM
dwhess504's Avatar
dwhess504
The pinion bearing... is that where it would leak close to the Driveshaft?
Old Aug 19, 2007 | 06:46 PM
jonnymagnum
yes
Old Aug 19, 2007 | 06:55 PM
imnothot02's Avatar
imnothot02
[sm=ttiwwp.gif]
