removing stock air box
Old Aug 21, 2007 | 09:02 PM
paxmaster2000's Avatar
paxmaster2000
Default removing stock air box
i am trying to put in a cold air intake in my 2004 dakota with the 3.7 v6 . the problem having is that i can't seem to get the the bolt off that is by the headlight. what do i need to use? i tried removing it with a 6 point socket but the bolt just turns and doesn't come out.
please help thanks
Old Aug 21, 2007 | 09:53 PM
asmodeus289's Avatar
asmodeus289
Default RE: removing stock air box
If you're talking about that plastic nut, then you can just pull up on it. I had to do that with mine too.
Old Aug 22, 2007 | 08:02 AM
dapirate559's Avatar
dapirate559
ORIGINAL: asmodeus289
i had to do the same thing for mine. its pretty simple.
Old Aug 22, 2007 | 11:50 AM
drjgarage's Avatar
drjgarage
Where is the cold air coming from??? It's getting air from under the hood, right? It would be just as good putting in an Air Hog or K&N.
Old Aug 22, 2007 | 01:38 PM
paxmaster2000
so what do i need to do to get it off?
Old Aug 22, 2007 | 03:51 PM
dapirate559
actually now that i think about it my cai went right into the stock air box. i have the airaid one. so i dont actually have to take the box off
Old Aug 22, 2007 | 04:30 PM
asmodeus289
Grab the bracket the plastic nut is holding downand pull the whole thing up.
