Have an ABS problem
Old Aug 28, 2007 | 12:40 AM
RandyP54's Avatar
RandyP54
Default Have an ABS problem
Got a '98 Dakota Sport Ext cab. Had to replace the rear speed sensor. Now when I slow down, the rear brakes lock up and I can feel a pluse in the pedal. When I pump the pedal once, everything is fine untill I stop again. The dealer couldn't figure it out, he told me to pull the fuse. Won't be going back to him. Anybody got any ideas?
Old Aug 28, 2007 | 01:28 AM
dapirate559's Avatar
dapirate559
Default RE: Have an ABS problem
how r the pads? do u have drums in the back? does it do it when you back up?
Old Aug 28, 2007 | 09:40 PM
RandyP54's Avatar
RandyP54
Pads are new, Front rotors and rear drums have been turned. Does it when I back up. What do you think?
Old Aug 28, 2007 | 10:00 PM
User's Avatar
User
uhh.. adjust your rear drums.. if you take off the drum there is a little clicker wheel click it till the pads and drum bearly touch each other..
it sounds like who ever did your brakes adjusted them to far out... adjust the pads in.
