i have a rim problem
Old Aug 31, 2007 | 09:11 PM
dapirate559's Avatar
dapirate559
Default i have a rim problem
hey guys i just got a hell of a deal on a set of dunlop mud terrains. they r on 15 inch rims and i have stock 16's the new rims and tires wont fit because my calipers front and rear are in the way. so what could i do by tuesday to get those rims to fit. the reason i need to get it by tuesday is because they are towing the truck they are on then. so any ideas would be open.
Old Sep 1, 2007 | 09:53 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: i have a rim problem
sorry to tell you but, 15's will NOT fit on your truck. since you have disc brakes front and rear.
Old Sep 1, 2007 | 12:06 PM
dapirate559
ok thats what i thought. i was thinking maybe but in my head i knew it wouldnt work. thanks bro.
Old Sep 1, 2007 | 03:25 PM
rred's Avatar
rred
thoses tires run really cheap. i uses to have them on an old jeep. you can get them mounted for something like 85 a tire. there a good mud tire. loud on the road, and wear down fast, but cheap.
Old Sep 1, 2007 | 04:13 PM
dapirate559
ok so i found a det of 16's for my truck. they are 16x8's but i want them to stick out more. do you think it would be smart to put a 3/8 inch wheel spacer?
Old Sep 2, 2007 | 10:17 AM
jonnymagnum
I'm not a big fan of spacers. they put too much stress on the wheel studs.
Old Sep 2, 2007 | 11:11 PM
imnothot02's Avatar
imnothot02
ruins hubs too
Old Sep 3, 2007 | 12:09 AM
03dakota4x4's Avatar
03dakota4x4
i put 15 inch wheels on my 03'. They fit fine in the back but had trouble in the front. Just took a grinder and shaved down front calipers and have had no problems.
Jon
Old Sep 3, 2007 | 04:08 PM
imnothot02's Avatar
imnothot02
^ not a good idea...
Old Sep 4, 2007 | 01:23 AM
dapirate559
okk so then ill just find some rims with as little backspacing as possible.
