why won't it stop!?
Old Sep 5, 2007 | 07:35 PM
Chris's Avatar
Chris
Default RE: why won't it stop!?
No problemo.
Old Sep 5, 2007 | 07:53 PM
highpriestess420's Avatar
highpriestess420
no clue wtf a 180 thermostat is
Old Sep 5, 2007 | 07:58 PM
Chris's Avatar
Chris
Well, that might be your problem. You need to be running a mixture of water and coolant (some come pre-mixed so read the bottle carefully) You will need to flush out your wholoe coolant system and replace it with proper coolant if you want your truck to run right. Also, read thermostat: http://en.wikipedia.org/wiki/Thermostat#Mechanical
Old Sep 5, 2007 | 08:15 PM
snikr's Avatar
snikr
And if you are going to flush your coolant system it's a VERY good time to change the thermostat. At least that's what I do. The 180 is refering to the degrees the stat opens. And mine will make a bubbling noise when I shut it off and I've been ruining the A/C. The A/Cwas making the noise on my last two Dakota's.
Tom
Old Sep 7, 2007 | 10:21 PM
SrtHemi's Avatar
SrtHemi
My truck has been doing the same thing except it doesnt overheat. It does bubble sometimes also i have noticed that i have an antifreeze smell coming from the engine compartment. No leaks so i am thinking it is coming from the thermostat area and just sitting on the top of the engine boiling off. If i am right it isnt a big leak at all, any way i am gonna replace the thrmo with a 180 and i will probally use the paper gasket and instead of RTV glue im gonna use windshield urethane. That way i know it wont leak .
Old Sep 8, 2007 | 01:55 AM
User's Avatar
User
We had a ricer come into our shop, that never put coolent in his car, he just put straight tap water.. rusted everything out and the engine was worthless.
I would flush that engine as fast as possible and get some coolent in it, replace the thermo (only cost like 5$) and buy a gallon on coolent and keep it in your truck or garage. Also the res tank is NOT suppost to be filled up all the way. Its a recirculating system, and runs under pressure about 15psi, the res tank fills with coolent and then drops as the thermo opens and closes. If its empty fill it half way not to the cap. otherwise when you do turn off the truck it will overflow and cause a big mess and the bubbling noise as its more then likely spilling on the exhuast manifolds or something hot.
Old Sep 8, 2007 | 03:09 AM
98whitekota's Avatar
98whitekota
well i had the same thing happen and i came to find out that it was the heater core, or is it heater coil? regardless also when it happen to me i had like a vapor or smoke come out of my a/c vents when it was on. this happen to u?
